Forced Induction, Fuel Injection, Foreign Intelligence, Finland....
All the FI's are better than the Not Applicable's.
Turbo vs V6 in the mountains - Which has more power?
Let's use theoretical numbers to explain this with 2 cars that are the same and make the same power. One is boosted and tuned and the other is N/A but has a built motor. (theoretically). One is boosted and one is a plane jane V6.
@ Sea Level
Camaro (Boosted) = 300 RWHP
Camaro (N/A) = 300 RWHP
@ This Altitude
Camaro (Boosted) = 287 RWHP
Camaro (N/A) = 253 RWHP
Boosted is the way to go. I'll tell you from experiance with my brothers cars that a boosted V6 pulls like nobodies buisness uphill @ 5psi. Go beyond 5 psi and the acceleration fun begins with no struggle. A V6 N/A Mustang would struggle on the same hill.
@ Sea Level
@ This Altitude
Another way to look at it is this (from what I've read):
A forced induction car loses roughly 1% of its HP for every 1000 feet of altitude. A N/A car loses about 3%.
So compare my buddy's stock 2005 Mustang GT and stock Mazdaspeed 6.
At sea level:
Mustang: 300 HP
MS6: 274 HP
At 6600 feet (Co Springs):
Mustang loses about 20%: 240 HP
MS6 loses about 7%: 256 HP
At 10K Feet:
Mustang loses about 30%: 210 HP
MS6 loses about 10%: 246 HP
So as altitude rises, the gap between the two increases.
THose numbers are approximate, though, and every engine is different. The newer G35s and the G37s (and the 370Zs) have a twin intake system that doubles the amount of air into the motor. They don't lose as much power up here.
At sea level:
Mustang: 300 HP
MS6: 274 HP
At 10K Feet:
Get a V8. The V8 Pontiac Grand Prix GXP I drove up and over Loveland Pass (11,990 feet) had no issues what so ever passing semis on the steep climb. Doing the speed limit on that road was tough- doubling and tripling it, however, was not.
Stealth01 wrote:THose numbers are approximate, though, and every engine is different. The newer G35s and the G37s (and the 370Zs) have a twin intake system that doubles the amount of air into the motor. They don't lose as much power up here.
The twin throttle body intake system on those Nissan's has nothing to do with power gains in altitude.
The reason NA cars loose MORE power in altitude than their turbocharged (not supercharged, I will explain later) brothern is as well know in higher elevation air is less dense. Less dense air means less air is entering the motor. Less air means less fuel can be injected into the motor which in the simplest way I can explain it means less combustion efficiency. Less fuel and air is less power.
A turbocharger has an exhaust-driven turbine wheel that spins a compressor in a housing to create boost. The turbo delivers more air to the motor which allows for more fuel to be injected and thus greater combustion efficiency/power.
So in higher elevation, the air is less dense. We know at sea level air is 14.7psi. In elevations up here and higher you can see air as dense as 11psi or even less. So in order for the turbo to create the same boost it would at sea level, the compressor wheel spins faster (sometimes well over 120,000rpm) to create the same exact boost pressure. So if a turbo car hits 18psi at sea level it will hit 18psi in any altitude (although the boost threshold may be raised due to the compressor needing to spin faster).
The difference is it's starting with less dense air in the first place, and that's where the power difference comes in.
An NA motor has no means to compress the intake charge, so it starves for air.
A supercharger, on the other hand, has its compressor driven by engine RPM. The compressor will always spin the same speed because it is mechanically tied to the motor. So, say the compressor of a supercharger spins at 35,000rpm at full boost. It can't spin any faster than 35k rpm so at altitude the supercharger has no means to compensate for the decrease in density- the compressor will always spin the same speed and thus can't spin faster to compress the air more. This is why supercharged cars will also suffer in altitude.
You can modify an NA car to make more power, but it will ALWAYS loose power in altitude more than a turbo car. A dual intake/throttle body setup will increase air, no doubt, but it does this at sea level, as well. So there is no "extra air" or anything coming in at altitude.
Additionally, with a turbo car, if you modify it properly to the point where you can install a boost controller, you can add 3-5psi in altitude to the point where you aren't loosing any power.
As Eric pointed out before as well, some factory cars have a PSIA and Baro sensors that can detect atmosphere air pressure and adjust preset boost pressures according. So at sea level, the car will operate with less boost pressure (say 10psi) and then when it gets into elevation, the cars ECU can automatically adjust and raise the boost limit (to say 14psi) to compensate. I know the newer BMW twin turbo motor do this as well.
Users browsing this forum: No registered users and 166 guests
