The curse struck outside colorado
Postby Huzer » Mon Oct 05, 2009 9:14
bobopud wrote:Just make sure to insist that the quote to replace damaged parts uses new OEM equipment. If you don't tell them and don't follow through, they will use junkyard parts, or knockoff stuff to save money. It is your right to get new OEM parts.
As I found out with my ordeal, insurance companies consider junkyard parts OEM. The saving grace, however, is that many "new" condition junk parts are priced over new OEM parts. Nevermind, of course, that new parts don't come painted, etc.
Good luck with everything. That looks to be a rather scary incident. Just glad that everyone is ok.
T-time
Postby T-time » Mon Oct 05, 2009 9:14
As long as the car is new condition afterwords I'll be happy, if they don't do a good job fixing it I don't have to accept it right? Were are some good collision shops in the springs. I need to call some today
Renesis Rx
Postby Renesis Rx » Mon Oct 05, 2009 9:14
Call ABBRA. They're right next to Home Depot on South Academy. I've used them 3 times and they do really good work.
Renesis...MMMMMMMMM
T-time
I was reccomended to them by another person also
T-time
Postby T-time » Tue Oct 06, 2009 9:14
its at abra now, i have the worst rental car in history (chevy hhr)
Justin
Postby Justin » Tue Oct 06, 2009 9:14
As if being run over by a bus wasn't bad enough...glad you're OK.
Postby iani1.1 » Wed Oct 07, 2009 9:14
T-time wrote:its at abra now, i have the worst rental car in history (chevy hhr)
lol couldve been worse. couldve been a pt loser
T-time
Postby T-time » Wed Oct 07, 2009 9:14
hey so heres a update, i went to the shop got the prelim estimate. the cost right now is about 5200 but its going to go up. they didnt have the correct tire being replaced in the front, they have to replace the rocker panel, and now the best part:
as i walk up to the car i notice the back tires are sagging weird, i look closer and see that both rear tires have steel showing on the insides of them (sh!T), the problem here is the shop has no way to prove to usaa that it wasnt like that before the accident. LUCKILY for me, i had it aligned right before i went home. TM i have to call big o on south nevada (were i got it done) and find out if they saved the alignment specs in the computer when i got it done. If they did, i can goto the shop and show them the printout saying it was fine before. ian from here did it along with some other guy, and it was in spec when i left. long day, and tm will be another one
T-time
Postby T-time » Sun Oct 25, 2009 9:14
I got my car back and abra fucked it up almost as bad as when i gave it to them.
I pulled out of the lot and realized when they put the new door on (front right) they didnt put my speaker and tweeter in from my old door (aftermarket), so I called up and the general manager said come in monday and they will fix it. ok cool.
Then I drive around for a little and decide to fill up, gas door doesnt pop, I leave them a message but then decide I shouldnt have to wait for monday to drive my car since they shouldnt have released the car incomplete. I goto mazda and the tech takes a screwdriver, wraps it in a towel and pops the tank. But scratches it, he apologizes and I say fuck it, this is abras fault because if they did the work correctly this wouldnt have happend.
I drive home and its getting dark, i realize the front right window is scuffed. They didnt replace the glass that had a big scratch/scuff from the bus hitting it.
Also they jacked my spare tire, which was in the back seat. And my front right tire rubs whenever i turn left, it didnt before they "fixed it"
Postby GR-8 » Sun Oct 25, 2009 9:14
That sucks go back abd demand it to be fixed. all of it.For all that money the insurance paid it should be perfect.
T-time
if they arent begging for forgiveness tm im calling usaa and complaining
Postby tbot » Sun Oct 25, 2009 9:14
that sucks dude...i'm really sorry to hear. I hope all gets taken care of.
T-time wrote:if they arent begging for forgiveness tm im calling usaa and complaining
I would call your insurance and let them know about it. Don't wait to long. Do it ASAP. Mebe Abra can't fix the Suspension problems but since it's from the accident the insurance comp. should pay a specialty shop to fix it.
But the gas door and the shoty work.... Abra should fix that no questions asked.
Renesis Rx
Postby Renesis Rx » Sun Oct 25, 2009 9:14
that sucks man. I can't belive they didn't do it right the first time. both times I used them it was like new. sorry man.
Renesis...MMMMMMMMM
T-time
Postby T-time » Mon Oct 26, 2009 9:14
i took the wheel off yesterday and its rubbing because they didnt replace the wheel liner / stone gaurd or they didnt attach it all the way now its all chewed up and bent
