Stalled Upon Start Up...
jenglis
Postby jenglis » Wed Jan 02, 2008 9:14
Sounds like my car....it's been at the dealer since Monday.
Postby tsx_guy » Wed Jan 02, 2008 9:14
does having it in gear or not while parked overnight really make a difference during start up?
Postby TheNewBlack » Wed Jan 02, 2008 9:14
I have had this happen once...it was very cold that morning. Hasnt happened for about 3 weeks though.
Postby Colombia28 » Wed Jan 02, 2008 9:14
From what iv read after the guy on the 3 forums pm'd me is that the problem is more than likely with the purge valve. So i call Sil-Terhar this morning because im in Boulder so its the closet dealer, and to my dismay the service guy says there is nothing he can do about it until it throws a CEL :huh: ...... wtf! So let me get this straight, my car more than likely has a genuine problem but they wont look at it until it gets worse and throws a CEL! Ummm k thanks i guess. Josh when im down in HR on Friday, if i were to bring it to Burt (like i should have thought from the beginning) would they look at it? Or is it the same story with no CEL SOL?
turbo99jetta
Postby turbo99jetta » Wed Jan 02, 2008 9:14
andrew, the biggest problem is that if they can't duplucate it, they can't fix it. basically unless they see it happen mazda won't pay them for warrenty work thats why no one will touch it. A CEL codes into the software so they can pull that. that way they get paid.. get what im sayin? No one works for free.. lol
Postby AIM WO4 » Wed Jan 02, 2008 9:14
<div class='quotetop'>QUOTE (Colombia28 @ Jan 2 2008, 11:24 AM) [url=index.php?act=findpost&pid=16102]<{POST_SNAPBACK}>[/url]</div>
From what iv read after the guy on the 3 forums pm'd me is that the problem is more than likely with the purge valve. So i call Sil-Terhar this morning because im in Boulder so its the closet dealer, and to my dismay the service guy says there is nothing he can do about it until it throws a CEL :huh: ...... wtf! So let me get this straight, my car more than likely has a genuine problem but they wont look at it until it gets worse and throws a CEL! Ummm k thanks i guess. Josh when im down in HR on Friday, if i were to bring it to Burt (like i should have thought from the beginning) would they look at it? Or is it the same story with no CEL SOL?[/b]
Give Burt a call. They are pretty busy, so dropping in might not be the best course of action.
MS3_Mafia
Postby MS3_Mafia » Wed Jan 02, 2008 9:14
Today was the first time I started my car in the past 9 days and it did stall just once... Reved the RPMs to about 2000K for a couple of seconds and it was fine. I forgot how fast our Speeds are since it was a while since I've driven it. :D
2007 Mazdaspeed3 Sport</span>
-Mazdaspeed Short Ram Intake
-HKS SSQV Bov
-Tein S-Tech Springs
<div class='quotetop'>QUOTE (Freezing Cx7 @ Jan 2 2008, 02:23 PM) [url=index.php?act=findpost&pid=16119]<{POST_SNAPBACK}>[/url]</div>
andrew, the biggest problem is that if they can't duplucate it, they can't fix it. basically unless they see it happen mazda won't pay them for warrenty work thats why no one will touch it. A CEL codes into the software so they can pull that. that way they get paid.. get what im sayin? No one works for free.. lol[/b]
Of course, but its not an uncommon problem from what iv read, even read there is a TSB out on the purge valve. Just strange that mazda feels its cool to just let a brand new car stall out upon start up and then tell me ill have to wait until it gets worse, or if it doesn't get worse, live with it...
and when i say "mazda" i dont mean as a company per say. I dont really care all that much that it does this, its not harming anything, but its just kind of screwy.
firestoned
Postby firestoned » Thu Jan 03, 2008 9:14
Andrew, my car has done the same thing a few times in the mornings when its cold as hell..the temp gauge reads 10-15, it stalls once, I restart it, let the clutch out slower, and its fine. After driving for a few minutes those couple times it happened, the temp gauge did give me actual readings of -2 degrees. Its gotta be because the clutch is cold, almost frozen to itself, when you let the clutch out too fast, it drags the rpms down and kills itself.. I guarantee it doesnt happen if you leave your foot on the clutch for about the first minute, giving little revs here and there.. Its the same with the ebrake freezing...that happens to me too...
My advice, get a heated garage...
Postby Colombia28 » Thu Jan 03, 2008 9:14
<div class='quotetop'>QUOTE (firestoned @ Jan 3 2008, 08:11 AM) [url=index.php?act=findpost&pid=16198]<{POST_SNAPBACK}>[/url]</div>
My advice, get a heated garage...[/b]
Yeah that seems like another good explanation of why since it only happens when i release the clutch. And i would kill for a heated garage!
ZoomPrincess
Postby ZoomPrincess » Thu Jan 03, 2008 9:14
^^ Andrew, you already kicked your mom's car out of the garage.. geez, you just want everything! haha JK
<div class='quotetop'>QUOTE (CeXy7 @ Jan 3 2008, 10:24 AM) [url=index.php?act=findpost&pid=16226]<{POST_SNAPBACK}>[/url]</div>
^^ Andrew, you already kicked your mom's car out of the garage.. geez, you just want everything! haha JK[/b]
This is true, but only when im home. Im in Boulder right now, so its not a garage per say, more of a covered parking garage.
ZoomPrincess
Mine sits out all the time.. I dont think it has ever seen a garage.....
Postby Huzer21 » Thu Jan 03, 2008 9:14
I agree with Eric, try just letting the clutch out a little slower, or hold it in a sec longer before releasing it. Mine hasn't stalled, but the RPMs drop significantly when you let the clutch out, and then they build back up.
LM
Postby LM » Thu Jan 03, 2008 9:14
Funny thing was, I walked into Burt Mazda's service department, Ed was on the phone. He was calling the owner of a Mazda6, telling them that the reason his/her car stalled was because of the purge valve...funny...
