Ordered Cobb AP
milehighspeed3
Postby milehighspeed3 » Fri Apr 04, 2008 9:14
I pulled the trigger today! It's a pre-order, but I got free shipping, no tax, a small discount and I bought some other goodies as well. Rumors are for a release on the 14th, which should put it here around the 18th or so.
Postby Huzer21 » Fri Apr 04, 2008 9:14
Sweet! Congrats. Should have great results with the AP for the Speed3, I'll curious to see what kind of gains you get. Any initial numbers or hints yet from Cobb?
Postby GR-8 » Fri Apr 04, 2008 9:14
Niiicccceeeee!!! Congrats on your order.
arctic_blue83
Postby arctic_blue83 » Fri Apr 04, 2008 9:14
Did you get a chance to dyno before the AP? Can't wait to see what kind of gains you get from it....
milehighspeed3
I was at Revolutions for Dyno Day, put down 189hp & 234tq (i think), lowest of the Speed3's. Not sure if it was my winter setup or some heat soak from the ride down there or what.
No numbers released from Cobb, as of yet. Just kinda going on blind faith right now, I expect modest gains from the released Maps. I may move to stage 2 map with exhaust set-up this summer. I expect better gains from the protune, late this year. There are rumors about launch control and flat foot shifting, after release, which would be nice along with the fuel saver for my daily commute.
MS3_Mafia
Postby MS3_Mafia » Fri Apr 04, 2008 9:14
Awesome Scott!! Can't wait to see the gains. About how much may I ask...
2007 Mazdaspeed3 Sport</span>
-Mazdaspeed Short Ram Intake
-HKS SSQV Bov
-Tein S-Tech Springs
Postby Colombia28 » Fri Apr 04, 2008 9:14
:1a98aa81: YEAH SCOTT!! Hell yes! I am so so sososososososososoosossoosSOOOOO jealous!!!! I wish i wish i wish i had the money to pre-order it :( OH i want it so bad so bad so bad!
Postby SpeedRacer » Fri Apr 04, 2008 9:14
Scott are you dynoing the day you get it?
METHLAB
Postby METHLAB » Sat Apr 05, 2008 9:14
AP?
arctic_blue83
Postby arctic_blue83 » Sat Apr 05, 2008 9:14
<div class='quotetop'>QUOTE (METHLAB @ Apr 5 2008, 07:54 AM) [url=index.php?act=findpost&pid=38455]<{POST_SNAPBACK}>[/url]</div>
AP?[/b]
Cobb Accessport. It's a flash based tuning device, you just hook it up to your OBD II port and reflash/upload a new map into your ECU. When I flashed my STI, the first time, it only took about 20-30 minutes for the new map to load into my ECU. On most cars, Cobb raises the boost, has a hold a little more towards redline (if possible), leans out the AFR's a bit and if possible, might add in an extra degree of timing or 2. What's beautiful is that since you're basically reprogramming the ECU, you can get rid of fuel cut, raise your redline, remove the governor (if there is one), and toggle off check engine lights, so if your remove the cats, you can make sure it doesn't throw a CEL from it, very cool stuff. Flash tuning>Piggyback. They don't have dynos up for the Speed3 yet, but here's one for the WRX just to give you an idea what you're in store for:
http://www.cobbtuning.com/products/?id=3264
Plus, when they release their Streettuner/Protuner software for the Speed3, you'll either be able to tune your car yourself or have a professional tune it for you. Not to mention the ability to datalog, calculate performance, estimate fuel economy ect ect. Very cool little toy :)
METHLAB
WOWZERS! Thanks for explaining!
Postby SpeedRacer » Sat Apr 05, 2008 9:14
My wild prediction for Stage 2 flash SRI + Downpipe will be 45whp 55TQ. If not more.
Those numbers are of course with a protune.
milehighspeed3
Postby milehighspeed3 » Sun Apr 06, 2008 9:14
I'm not sure when it's going on the Dyno, cause I'm not sure when I'm going to get it, but I want to within the first week. I will keep everyone posted on the updates. It also should provide 0-60 times and 1/4 mile times, I plan to test it against the clock up at Bandimere this summer.I will also need some help with the other goodies, as I don't think anyone here locally has added these mods.
Postby SpeedRacer » Sun Apr 06, 2008 9:14
What goodies?
Users browsing this forum: No registered users and 48 guests
