So I know there are quite a few places to buy jdm Honda and Acura engines, but I'm in need of a Mazda engine. My 2005 MZ3 now has "rod knock", which requires either rebuilding the bottom end, or aswapping out for a remanufactured engine. I had some oil consumption issues in my car, which I'm sure led to the rod problem.
Having said that, I'm hoping some others have found good sources for quality Mazda 3 engines.
Thanks for any help in advance.
MAzda3 Engine Sources
You could try eBay...
http://www.ebay.com/itm/04-05-MAZDA-3-ENGINE-2-0L-/250992985732?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2005%7CMake%3AMazda%7CModel%3A3&hash=item3a70590684&vxp=mtr
- I`m Batman
- I`m Batman
Thanks EROD. I'm not sure if I want a donor engine. I was thinking remanufactured. I realize it came from a donor, but it has been gone over and generally has a warranty of sorts. The ones I found last night were all pretty high mileage, but not sure if that is a concern if they have been redone.
Also, I actually need a 2.3L engine. I forget that the 2.0L exists.
- I`m Batman
I`m Batman wrote:naw, you gotz ta get da B16b with B18 bottom end yo! Slam that chiet and put a coffee can muffler on there and put some 14" steelies up front and 20" in the back!
And don't forget ta hook it up wid some NAAAAAAAAWWWWWWWSSSSSSS!!!!!
I give you a thumbs down here sir... this post was no help, i repeat no help at all. (rotates 14" to rear of fwd car....)
Well if you're not willing to take a used engine and only a remanufactured one, then you're actually getting close to the cost of another used car. Especially if you don't have the tools/knowledge to put it in yourself.
http://www.powertrainproducts.net/Mazda-2-3-engine-03-05-3-6-models-p/2071.htm
- I`m Batman
- I`m Batman
I have someone willing to help me install the engine.
Thanks for finding that one erod. I prefer a remanufactured, because it should be as close to a new engine as you can get. A used one might have me in the same place in a short time. Might it be worth it if it holds up, you betcha, but the time and labor involved, as well as the inconvenience is pretty high. I realize I could have the same issues with a reman, I just think it is less likely (definately could be wrong).
a 4 year warranty is pretty solid.
Its not so much that I love the car, its more that I don't have 10k sitting around for another used car since I bought this one less than a year ago. And I actually have no idea what I want for my next car. I'm not closing my options completely. Just not able to think clearly about what I want to do exactly.
Users browsing this forum: No registered users and 138 guests
