I've been following what's been provided here: http://goo.gl/gWMS1
And it's all good except for that wiring harness. I can NOT seem to get those posts off of the threaded studs.
I don't have the special tool, so I've been trying the tiny slotted screwdriver, moving the tab both toward and away from the stud, and even tried pulling on it with a pair of pliers.
Anyone have a little nugget of insight for me?
as for the one on the front side of the cover, I don't see ANYTHING to push, pull, or otherwise manipulate.
HELP! All I wanna do is change the valve cover gasket!
2.3L valve cover removal - Wiring harness. Grr.
- RedRoadster
95 Classic Red Miata - 'Kona'
Flyin' Miata stuff:
Flyin' Miata stuff:
- AuroraAxela
They should just pry up. You're not going to break them, per se. They aren't threaded themselves, and will just push back on when reassembling.
- RedRoadster
The front side came off relatively easily. It won't snap back on, but I supose that's fine.
The back side broke off the plastic track across the top of the cover.
At that point I tried to pry it off and sliced myself up pretty good, so I took the hammer to it and just destroyed it off.
Good enough.
Flyin' Miata stuff:
Flyin' Miata stuff:
Actually, those are different. I did "destroy off" lots of clips though.
With the fasteners on the threaded posts, I actually just squeeze them with a pair of pliers and pull up. Squeeze on the sides with the tabs.
Anyone have an easy solution for removing an engine without a car hoist, or does anyone have a car hoist that won't be needed for a few days as I (well, another CMZC memeber) swaps an engine?
Users browsing this forum: No registered users and 82 guests
