2.3L valve cover removal - Wiring harness. Grr.
RedRoadster
Postby RedRoadster » Sun Jul 01, 2012 9:14
I've been following what's been provided here: http://goo.gl/gWMS1
And it's all good except for that wiring harness. I can NOT seem to get those posts off of the threaded studs.
I don't have the special tool, so I've been trying the tiny slotted screwdriver, moving the tab both toward and away from the stud, and even tried pulling on it with a pair of pliers.
Anyone have a little nugget of insight for me?
as for the one on the front side of the cover, I don't see ANYTHING to push, pull, or otherwise manipulate.
HELP! All I wanna do is change the valve cover gasket!
95 Classic Red Miata - 'Kona'
Flyin' Miata stuff:
AuroraAxela
Postby AuroraAxela » Sun Jul 01, 2012 9:14
They should just pry up. You're not going to break them, per se. They aren't threaded themselves, and will just push back on when reassembling.
RedRoadster
The front side came off relatively easily. It won't snap back on, but I supose that's fine.
The back side broke off the plastic track across the top of the cover.
At that point I tried to pry it off and sliced myself up pretty good, so I took the hammer to it and just destroyed it off.
Good enough.
Flyin' Miata stuff:
Postby kingtut » Sun Jul 01, 2012 9:14
RedRoadster wrote: destroyed it off.
Ha ha, good stuff. I too have used this very method, in past endeavours.
Postby speedjunkie » Mon Jul 02, 2012 9:14
If it's what I'm thinking of, I believe Shadowden destroyed a couple of those when we were doing his car lol. Those things are a PITA.
Postby Shadowden » Mon Jul 02, 2012 9:14
Actually, those are different. I did "destroy off" lots of clips though.
With the fasteners on the threaded posts, I actually just squeeze them with a pair of pliers and pull up. Squeeze on the sides with the tabs.
Anyone have an easy solution for removing an engine without a car hoist, or does anyone have a car hoist that won't be needed for a few days as I (well, another CMZC memeber) swaps an engine?
We have one but I'll be using it again this weekend hopefully and it's not even mine and the guys been wanting it back for a while lol.
Users browsing this forum: No registered users and 131 guests
