My New Toy
Postby RX-7 Chris » Fri Mar 18, 2011 9:14
Just finished installing some parts. I installed the vent, arm rest pad, steering wheel, sunroof crank, and the K&N filter.
Postby iani1.1 » Fri Mar 18, 2011 9:14
awesome. i just did a full tune up to mine last week. except the fuel filter which ill do tomorrow or something. it runs soo much better that i dont really have to pull the choke every morning lol
iani1.1 wrote:awesome. i just did a full tune up to mine last week. except the fuel filter which ill do tomorrow or something. it runs soo much better that i dont really have to pull the choke every morning lol
Did you get all the parts you got from me installed?
Postby RX-7 Chris » Sun Mar 20, 2011 9:14
Thanks to ecam8000 for all the help.
I got everything on the motor back together at about 6pm last night. I tried to start the car but was having trouble getting the fuel pump to prime. Today I'm going to install the new fuel filters, shark plug wires, and muffler. I will also do the tranny mount and drive shaft if I have time.
My rebuilt injectors:
They flow well one is 692 cc/min and the other is 702 cc/min at 43.5psi.
ecam8000
Postby ecam8000 » Sun Mar 20, 2011 9:14
Well, is it running yet?
Eric
2 Fords 29 & 2000.
99 BMW 328i
THANKS! To all who serve.
The car is now running. It actually started right up this morning. I think it just needed a rest after yesterday, lol.
I replace the spark plug wires and installed battery hold down this morning. I also got the muffler replaced. The muffler was a complete nightmare. The two bolts that attached the muffler to the midpipe were completely rusted on and I had to use a cutoff wheel on them.
Next on my list is the fuel filters.
ecam8000
So it is ready for DD duty again?
Eric
2 Fords 29 & 2000.
99 BMW 328i
Yup it seems to be doing good. I need to adjust the idle, mixture, and TPS a little but otherwise it seems to be doing good.
Postby kingtut » Mon Mar 21, 2011 9:14
RX-7 Chris wrote:Next on my list is the fuel filters.
Filters? Again with the fuel filter?
Really Chris, really?
Postby RX-7 Chris » Mon Mar 21, 2011 9:14
Yes I replaced the filters. I figured since I was replacing the injectors it would be a good time to replace the filters. I have one between the tank and the pump and the stock one after the pump.
Postby RX-7 Chris » Tue Mar 29, 2011 9:14
The car has been running good. I seems to be getting better mileage and doesn't smoke at startup.
Postby kingtut » Tue Mar 29, 2011 9:14
RX-7 Chris wrote:The [insert car with no pet-name] has been running good. I seems to be getting better mileage and doesn't smoke at startup.
Fixed. You're welcome.
Postby RX-7 Chris » Mon Apr 04, 2011 9:14
I worked on the car on saturday. I replaced the last coolant hose that needed replacing.
I'm very happy with onlinemazdaparts.com. They sent the wrong hose (it had the right parts number but was bagged wrong) so I called them to get it right. They sent a new one right away with a return slip for the old one, no questions asked.
I also did some more cleaning under the hood. I pulled the battery tray and painted it. I cleaned a bunch more grease off the motor.
Postby kingtut » Mon Apr 04, 2011 9:14
Finally changed out that pesky coolant hose, eh? Nice dude!
Here is the newest pic of the motor:
Users browsing this forum: No registered users and 295 guests
