Bandimere - 05/25/11
maybe someone here knows the answer... but what happens if you think you will run a 14-15sec ET and hit 13's? Asking as a helmet is required for 13.99 or faster but I don't have one and really have no idea what my Stock Evo X would run up here, but I think it would be fun to go down one of these days.
If you run a 13.99 that will be your last run of the day and they'll kick you out until you come back with a helmet. I would just get a helmet just in case. The stock Evo Xs I've seen have run 14.0-14.2, so you're already pretty close to needing one. And then if you mod at all, you should be in the 13s pretty easily.
erod550 wrote:If you run a 13.99 that will be your last run of the day and they'll kick you out until you come back with a helmet. I would just get a helmet just in case. The stock Evo Xs I've seen have run 14.0-14.2, so you're already pretty close to needing one. And then if you mod at all, you should be in the 13s pretty easily.
cool. I have a moto x helmet, but I would look a bit odd in that going down the track
I'll be hitting the track in a couple weeks, but it won't be at Bandimere. We're taking a road trip to Tulsa so I can see how the Mustang does closer to sea level.
Return to “Track Days and Events”
